[GiDlist] stl-import
Hallo
I have some trouble with importing surface mesh from stl-file with GID,
version 7.2. The mesh can be imported and is transformed into NURBS.
However, when trying to save it, the disk quota of 2GB is exceeded even
for a single triangle. Does somebody have an idea how to fix this?
Thanks a lot!
Best!
TImon
Thanks a lot!
Best!
TImon
[GiDlist] Save Problem
Hi GID team!
I've been to try save all assigned data of Condition Point
Load some problems but i did not get success.
My procedures are:
proc SaveGIDProject {filespd} {
set fp [open $filespd w]
if {$fp!=""} {
#save the specific problemtype data file contents...
# global DefaultSearchDirectory
# if { ![info exists DefaultSearchDirectory] || \
# ![file isdirectory $DefaultSearchDirectory]} {
# set DefaultSearchDirectory [pwd]
# set deft $DefaultSearchDirectory
# set aa [.central.s info Project]
# set ProjectName [lindex $aa 1]
# if { [file extension $ProjectName] == ".gid" } {
# set ProjectName [file root $ProjectName]
# if { $ProjectName == "UNNAMED" } {
# tk_dialogRAM .gid.tmpwin error \
# [_ "Before importing, a project title is needed. Save
project to get it"] \
# error 0 OK
# return
# set directory $ProjectName.gid
#WarnWinText "SaveGIDProject $filespd"
# close $fp
set dirinfo [lindex [.central.s info Project] 1]
set rootname [lindex [file split $dirinfo] end]
set from [file join [lindex [.central.s info Project]
1].gid $rootname.flavia.rst]
#set to [file rootname $filespd].flavia.rst
set to [file rootname $filespd].spd
WarnWin "Saving $to from $from"
proc AfterOpenFile { filename format error} {
WarnWinText "$filename $format $error"
if {$format == "GIDGEOMETRY_FORMAT"} {
set filespd [file join $filename [file tail
$filename]]
if {[file exists $filespd]} {
set fp [open $filespd r]
#read the specific problemtype data file contents
close $fp
#WarnWinText "LoadGIDProject $filespd"
I'm sending you the file of Point load.
When i save the problem type, the file *.spd is a empty
file.
How can i save the information of
[.central.s info conditions PointLoad] ?
Could you give some advice?
Thanks.
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060124/279eac8f/attachment.obj
My procedures are:
if {$fp!=""} {
# error 0 OK
# return
# close $fp
$filename]]
close $fp
file.
Thanks.
[GiDlist] Get Elements for selected node
i need to get the information about what elements are connected to a
specific node.
I want to select the node via a condition, and write to file what
elements are connected to it.
Any Ideas?
Thanks in advance
Bjoern Brodersen
Dipl.-Ing. Björn Brodersen MSc
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Tel.: 0531 / 391 - 3670
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Maybe is a corrected bug.
Try to download the last avalable beta version 7.7.5b
If the problem persists, send us a sample model (small if possible),
directly to escolano at cimne.upc.edu
In other hand, when you import a stl as surf-mesh it's not converted to
NURBS, it's created an
special pseudo-surface entity where the shape is really the mesh
triangulation.
From: "Timon Rabczuk" Timon.Rabczuk at lnm.mw.tum.de
Sent: Tuesday, January 24, 2006 11:21 AM
Subject: [GiDlist] stl-import
Hallo
Thanks a lot!
Best!
TImon
triangulation.
Hallo
Thanks a lot!
Best!
TImon
Dear Enrique
Thanks a lot for the tip. It works with the beta version.
Best!
Timon
triangulation.
Hallo
Thanks a lot!
Best!
TImon
Best!
Timon
triangulation.
Hallo
Thanks a lot!
Best!
TImon
This information is not directly available inside GiD. Do you have direct access from the elements to the nodes, but not the inverse.
The node has only a counter (higherentities) of elements referencing it .
In other hand, you can write a simple tcl procedure in order to do this, for example some like this (it's untested):
proc ElementsOfNodes { } {
foreach elementtype [lrange [GiD_Info mesh] 1 end] {
foreach elem [GiD_Info mesh elements $elementtype 1 end -sublist] {
set num [lindex $elem 0]
set nodes [lrange $elem 1 end-1]
foreach node $nodes {
lappend elemsofnode($node) $num
#return a string with this information
set ret ""
foreach node [lsort -integer [array names elemsofnode]] {
append ret "$node $elemsofnode\n"
return $ret
Note: you can call this tcl procedure from the .bas template, with *tcl(ElementsOfNodes). The returned value is directly printed to the output calculation file.
From: "Björn Brodersen" bjoern.brodersen at tu-bs.de
Sent: Tuesday, January 24, 2006 12:25 PM
Subject: [GiDlist] Get Elements for selected node
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060124/c542f530/attachment.htm
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
thanks for this first "direction"
Unfortunately I'm not familiar with tcl, so it will take me some time to
answer whether this code works or not. First try revealed that line
has [dont know why
] to be
foreach node [lsort -integer [array names elemsofnode($node)]] {
to get no error on execution.
Can you give me a hint on how to shorten the procedure of loading the
problemtype over and over again after changing the tcl- file ? This will
surely ease my "trial and error" -tcl learning.
I will report when i get an working tcl function in this thread.
Thanks Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
has [dont know why
Thanks Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Hi again,
can anybody give me a hint about how to get some output out of this
function? Testing some "puts" and such doesn't work.
I understand the basic Idea of getting the information, but I'm still
stucked with the tcl thing.
Do I have to use
*tcl(ElementsOfNodes [arguments]) ?
Please give me an advice how to get some output, even if its only a
string "..." from the tcl proc...
Greeting and thanks
Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Do I have to use
Greeting and thanks
Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
About my previous code, there is a small error (as I said it was untested)
instead
must be
append ret "$node $elemsofnode($node)\n"
but [array names elemsofnode] is ok, it returns a list containing the names of all of the elements in the array
I sorted this list with lsort to obtain the list of nodes increasing its number.
Can read the standard documentation of the standard Tcl commands at
http://www.gidhome.com/ManHtml/tcl8.4.9/html/TclCmd/contents.htm
About the special GiD commands, like GiD_Info or GiD_Process, can read the GiD help on Tcl-Tk extension
http://www.gidhome.com/support/gidbeta/gid_18.subst
In order to use this code, if you have your problemtype, add a file named yourproblemty.tcl, this file will be automatically loaded when loading the problemtype. And can write the calculation file in your required format with a yourproblemty.bas template, that can call the tcl procedure.
(read the GiD help customization chapter)
Can use the GiD-tcl procedure WarnWinText to have a non-modal window with the output.
A trick of the GiD command line is to use -np- to evaluate a tcl command,
for example, after load the procedure in GiD, can use
-np- WarnWinText [ElementsOfNodes]
The last GiD beta versions include RamDebugger: a editor and debugger for Tcl/Tk code.
Can start this debugger from the menu: Data-problemtype-Debugger...
Can write the code in this tcl developper environment, and run it with F5. Also it include the Tcl/Tk reference help
(it's a contextual help, for example if select the 'array' word and press F1, automatically go to the help on this topic)
I understand that it's a lot of information to begin, but don't worry about.
If you are not familiarized with the GiD customization concepts, I recommend you to follow the 'problemtype tutorial' http://www.gidhome.com/support/su05.subst.
Sent: Tuesday, January 24, 2006 5:42 PM
Subject: Re: [GiDlist] Get Elements for selected node
has [dont know why
] to be
Thanks Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060125/a2ced5ea/attachment.htm
instead
must be
has [dont know why
Thanks Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Great !!!!!
This is exactly what i needed...
Thanks for the help,
Greetings Bjoern
instead
must be
has [dont know why
] to be
Thanks Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Greetings Bjoern
instead
must be
has [dont know why
Thanks Bjoern
set ret ""
return $ret
specific node.
Any Ideas?
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
