It's my first topic on the GiD forum. I try to handle this software, in the version 10.0, but I failed to mesh my model properly. My model is quite simple: it is a cube, defined by 8 points (4 apartments on the top face, a first layer, and 4 apartments on the bottom face, a second layer) as well as the 4 other faces, defined respectively in different layers.
When I mesh my model, on a corner the nodes are multiplied, do you know how to adjust this parameter and thus create "unique" nodes (see screenshot below) ?
Thank you in advance for your feedback and respectfully,
Victor Desloges
