What's the Difference Between 32-Bit and 64-Bit in the GiD program on Windows OS?
jinsu421
Post by jinsu421 »
Hello, GiD Team.
I need to explain about installation about GiD Program for my customer.
Please tell me 'Really Difference' about x86 ver and x64 ver.
Thanks.
jinsu421
Re: What's the Difference Between 32-Bit and 64-Bit in the GiD program on Windows OS?
Post by jinsu421 »
Is it ok to install with x86 version if there is no difference in performance?
A 32 bits program use 32 bits (4 Bytes) for memory addresses, then the maximum memory that can handle is 2^32=4.294.967.296=about 4GB, (2 or 3 GB in practice).
In practice,in Windows a x32 process that spend more than 2GB will crash.
A 64 bits program uses 8 Bytes for pointers, and can theoretically handle 2^64= much more than the physical available memory.
Then a process could spend the whole physical memory.
With 2GB of process is possible to generate a maximum of about 10 millions of tetrahedra
About performance in velocity is similar in both versions.
A Windows x64 platform could run both GiD versions, x32 and x46.
A Windows x32 platform could run only a GiD x32 version
