I wanted to change the format of the numbers along the axis on a graph. Unfortunately changing the results format (Preferences - Format) doesn't have any influence of the format of these numbers. Is there any other command or possibility to adjust this format?
Because I don't want to use exponential representation of a number (1,000,000 instead of 1E+06) along an axis.
Peter
graph - format of the numbers
Re: graph - format of the numbers
Unfortunately there is no option to change the number format for graphs.
We will discuss it in order to include it in next versions.
