SV: [GiDlist] (no subject)
I think that I have now tried everything. I attach the sample (geo-file) and as you can see it’s not too complicated. It consists of a small cylindrical hole in a larger cylinder. I’m using version 6.1.2.
Kind regards,
Mel.
-----Oprindelig meddelelse-----
Fra: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es]På vegne af Enrique Escolano
Sendt: 11. april 2002 09:34
Til: gidlist at gatxan.cimne.upc.es
Emne: Re: [GiDlist] (no subject)
Choose another Meshing Preferences (Utilities-Preferences)
  • Try for example: mesher=RSurf, Automatic correct sizes=Selected, and
    Unstructured size transitions=0.7
  • Choose a mesh size appropiate to the body size.
You can also assign a specified unstructured size to points, lines, surfaces
or volumes.
If this fail, send us the sample to check it
(indicate your GiD version, see Help-About)
Sent: Thursday, April 11, 2002 1:16 PM
I’m trying to mesh a solid with a hole. I do the following:
1. Create the main volume
2. Create the hole volume
3. Choose Geometry|Create|Volume|Hole and choose first the main volume and
the the hole volume as prompted.
4. I then try to generate the mesh and the following message appears:
Stopped meshing near point: 1.414214 0.471405 9.166667
Elements generated: 122. Faces in last front: 142
Status error for tetrahedra mesher is: Couldn’t find point
What am I doing wrong?
Mel.
MSN Photos is the easiest way to share and print your photos:
_http://photos.msn.com/support/worldwide.aspx_
Name: not available
Type: application/ms-tnef
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020415/f7c5f5f8/attachment.bin
The geo file is missing.
You can send it to the GiD list or directly to escolano at cimne.upc.es
Sent: Monday, April 15, 2002 9:31 AM
Subject: SV: [GiDlist] (no subject)
Kind regards,
Mel.
or volumes.
Mel.
