Having worked on a large and demanding moment lately, I’d like to suggest some possible improvements for the upcoming versions.
when you rename a material/element, it would be helpful to prompt the existing name in the edit box. The same could apply when copying (new) an existing material/element adding the suffix ‘-copy’. This is necessary because there is no way to copy/paste text from the window.
when displaying all materials, invisible layers/groups should be respected, instead of showing all elements.
color legend should show all entries, not grouping entry 15 and up to ‘Other’ with the same color. Multiple columns can be shown if necessary.
