Results on particle elements
I use GiD 15.0.4, and I am trying to visualise values on point elements. I want to store them as Gauss point values. I have used the default Gauss point set, GP_POINT_1, and created a Result section for point elements, where a single scalar value is assigned to each point element. In addition to the point elements, the mesh also contains quadrilateral plane elements whose nodes are shared with the point elements. The problem is that no results are displayed for point elements after the View results→Contour fill command. My idea was to use point elements at nodes to substitute dimensionless spring elements attached to the main structure. See the mesh file and excerpt of the result file at the end of the topic.
Tomas
Mesh file:
MESH “1-spring_1” dimension 3 Elemtype Point Nnode 1
Coordinates
1 0.000000e+00 0.000000e+00 0.000000e+00
2 2.000000e+00 0.000000e+00 0.000000e+00
3 4.000000e+00 0.000000e+00 0.000000e+00
4 0.000000e+00 2.000000e+00 0.000000e+00
5 2.000000e+00 2.000000e+00 0.000000e+00
6 4.000000e+00 2.000000e+00 0.000000e+00
7 0.000000e+00 4.000000e+00 0.000000e+00
8 2.000000e+00 4.000000e+00 0.000000e+00
9 4.000000e+00 4.000000e+00 0.000000e+00
end Coordinates
Elements
5 1 12
9 4 13
10 7 12
end Elements
MESH “1-spring_2” dimension 3 Elemtype Point Nnode 1
Elements
6 1 12
7 2 13
8 3 12
end Elements
MESH “1-Quads4” dimension 3 Elemtype Quadrilateral Nnode 4
Elements
1 1 2 5 4 11
2 2 3 6 5 11
3 4 5 8 7 11
4 5 6 9 8 11
end Elements
Result file:
GiD Post Results File 1.0
GaussPoints “23” Elemtype Quadrilateral “1-Quads4”
Number Of Gauss Points: 4
Nodes not included
Natural coordinates: given
5.773503e-01 5.773503e-01
5.773503e-01 -5.773503e-01
-5.773503e-01 5.773503e-01
-5.773503e-01 -5.773503e-01
end GaussPoints
Result “eps_e_1” “0” 0 Scalar OnGaussPoints “GP_POINT_1”
Values
5 2.500000e-06
 9  2.500000e-06
10  2.500000e-06
End Values
Result “eps_e_2” “0” 0 Scalar OnGaussPoints “GP_POINT_1”
Values
6 8.470329e-22
 7  4.764560e-22
 8 -1.323489e-22
End Values
Result “eps_e_x” “0” 0 Scalar OnGaussPoints “23”
Values
1 1.250000e-06
1.250000e-06
1.250000e-06
1.250000e-06
 2  1.250000e-06
    1.250000e-06
    1.250000e-06
    1.250000e-06
 3  1.250000e-06
    1.250000e-06
    1.250000e-06
    1.250000e-06
 4  1.250000e-06
    1.250000e-06
    1.250000e-06
    1.250000e-06
End Values
You are right. It seems that results ‘on gauss points’ of elements of element ‘Point’ of 1 node are not drawn.
e.g.
result_GP_POINT1_and_quadrilaterals.gid.zip (1.3 KB)
We will implement it for next GiD versions
But instead of define the result on the gauss point of this special ‘Point 1-node element’ you can define it on the node of the element, like my attached example, then it is drawn
result_Nodal_and_quadrilaterals.gid.zip (1.2 KB)
