results animation window
Hi all,
I am trying to use results animation window to show the variation of deformation with time as a result of an applied ground motion. By using GiD 13 the time is running but no change to the recorded deformation shows up? Kindly, could you help me with this issue? knowing that, I have tried the GiD 12 version and the variation of the results with time is shown.
Kind regards
albasha
Have you set that the main mesh must be shown deformed with some vector result?
(then the mesh is shown adding to the coordinates the vector result, with an scale factor)
or maybe the factor is too small to appreciate the deformation?
And during the animation is the checkbutton ‘Deformation’ set?
If you are unable to do it attach a zip with some small example.
Thnk you so much for your kind help.
