It seems that “Print to file” “SVG..” in mesh drawing corrupted.
Please, attach a zip with the GiD model.
I have tried with a similar model, it is attached
test_svg.zip (18.7 KB)
and it worked well
This is a screen capture opened with the InkScape editor
Thanks for the reply.
I attached zip file; my testing model is in it.
Am testing it by GiD 15.0.3 (free version).
testingSVGexport.gid.zip (25.8 KB)
Hi Hemmi,
Are you using an AMD Radeon graphics card? Which graphics card are you using?
We found a similar problem with the drivers of AMD Radeon cards and are solving it.
Can you try the Preferences → Graphical → System → ‘Safe visualization mode’ ?
and see if the SVG is exported correctly?
Can you send us your gid.ini file (located at c:\users<YourUserName>\AppData\Roaming\GiD\15.0.3\gid.ini) ?
thanks,
gidteam
Thank you for the answer.
The graphics card of my laptop PC (Lenovo ideapad 330S-14IKB) is
Intel(R) UHD Graphics 620.
After changing to “Safe visualization mode”, the correct figure is drawn; thus the problem solved.
The attached gid.ini file is the version after “Safe visualization mode” applied.
testingSVGexportMESHsafevisual.zip (16.7 KB)
