I have generated a model using Gid pre-processing and extract the OpenSees .tcl code file.
I have modified the file without changing nodes, elements, meshes, boundary conditions, location of loads and recorders.
I executed the OpenSees file and got the results in the same folder.
How can I use these results for post-processing?
I don’t know which files are writting when running OpenSees.
Is it writing some results file with GiD postprocess format?
then the normal way is to have the GiD model as a folder with .gid extension
e.g.
.gid
and inside there are the GiD files with the same name and different extensions, like .geo for the geometry, .msh for the preprocess mesh, etc.
The results file must be named .post.res
then when changing from pre to post it will be automatically read
(a possible .post.msh could replace the mesh for postprocess)
In postprocess mode you can also manually open a .post.res/.post.msh file selecting it with Files->Open…
(in preprocess model Files->Open… will read the whole model, represented by the .gid folder)
