Possible to source tcl file with arguments
I would like to run GiD from the command line and have a tcl script act on it as follows:
gid -n -t tcl_script_path
Unfortunately my script also needs 2 command line arguments. So I tried this
gid -n -t “tcl_script_path arg1 arg2”
Which didn’t work. Then I tried to source it from within GiD session as follows:
-np- source {tcl_script_path arg1 arg2}
But I got the following error Error: couldn’t read file ….
How do I run a tcl script on GiD using command line arguments from the cmd command line (black screen)? Thanks…
Is not valid, because the Tcl ‘source’ standard command expects only an argument, the Tcl filename to be sourced.
Its syntax is
source $filename
and about the GiD command line
gid -t tcl_script_path
is not valid because this syntax expects a tcl command, not a filename to be sourced
if the command already cannot be used, because it is not defined, you must before define sourcing it
e.g.
gid -t “source <your_filename> ; <your_procedure> <argument_1> … <argument_n>”
or you can invoke your procedure directly inside your filename sourced.
