No subject
Information about GiD licenses is in:
http://gid.cimne.upc.es/support/faq-manual_8.html#SEC39
Now on, it is necessary that you calculate by yourself the faces
numbers from the elements numbers with an ordering algorithm.
As the people that needs this kind of information increases, it
will be necessary to give this kind of data by the normal means of
the BAS file.
Antonio M. F. Frasson writes:
Would you please can give me two informations ?
First : I need to change my system ( processors, main board and hard
disk), then I will need to chance my system number. Can I change the
number to install the GID in the new system? ( I bought a license in last
year ).
Second : I need the edge numbers, can I obtain these number of the GID? If
these is possible, how?
I am working in finite elements for electromagnetics and I am utilizing
edge elements, now I am numbering the edges utilizing the nodes numbers,
but these transform my final system of equations with a very irregular
sparse pattern and the solution implies in a large number of fill ins. If
I obtain the edges numbers of GID date structure, I and others that work
with GID in electromagnetics, this is the case of my laboratory in
UNICAMP,Brazil, will have our work been facilitate.
Antonio Manoel F. Frasson
Numèrics en Enginyeria
ramsan at cimne.upc.es
C/ Gran Capitan s/n,
