no_structure_visible
Dear Colleagues,
I have windows10 (64bits).
When I start GiD (14, 16) it opens the window normally.
I go to postprocessing, then I read the *.res (*msh as well).
Then, I want to see the structure (rendered, solid body).
However, I do not see the structure.
But, I can choose results. The legend with the
intervals of the results appears.
However, I cannot see anything.
It happened some time ago.
I had been working on the same system for long time normally.
Could you be as kind as to give a hint ?
Eligiusz
Probably do you have some rare user settings.
Reset them: https://gidsimulation.atlassian.net/wiki/spaces/SD/pages/1210057206/Reset+all+user+preferences
