Hello guys,
I want to mesh shell structure by using a “hexaeder elements”. There will be underlying and also extruded surface, also thickness direction - perpendicular to the surface.
Right I extrude a curve to a surface (translate + extrude) to generate geometry. After that I’m extruding result surface to volume - offset + extrude. At the ent I mesh the volume.
Well. in my FE calculation element’s definition is sensitive to mesh numering, so first four nodes should be in lower surface. Second four nodes should be in upper surface. My problem starts, because structured mesh generated by GID may be oriented in the plane of the shell instead of perpendicular to it (each is Hexaeder is turned by 90 degree).
And my question is: is there any way to get better control over the node numbering?
Thanks for your reply,
Best regards!
