Maximum and minimum
Is it possible to ask for a maximum (or minimum) of a single quantity on a node (or element) across ALL steps ?
For example,
1- it is possible to show a graph of a result on a selected node along the time
View results->Graph->Point evolution
In the graph you can visually see the maximum,
then show its label/result , show a table with the x,y values (allowing edit, copy/paste with other programs like Excel,…)
2-you can also create a new statistical result derived from the results along the time step (on the whole model, not only in some node/element)
Window->Create statistical result…
you can select the operator ‘maximum’ and all time steps and you will have a new result (defined only in the last time step) with the maximum value of all time steps.
Then you can draw it, list some entity to see the maximum of this entity
