I’ve found strange problem please advice what I did wrong.
I want save the post-process results in higher resolution that just make a print screen.
I’ve setup “page and capture settings” and press “snapshot” button.
In a snapshot file i see that GiD render wrongly legend if i set landscape orientation and resolution higher than 550dpi.
When i use resolution 600dpi program cut the legend (higher value) not rendered in a snapshot, for higher resolution legend not rendered correctly at all.
I’m using GiD 12.1.7d and GiD 11.0.8 as a file format for snapshot I use png.
I forgot to write that font for the legend is changed to the “Times New Roman 18 bold” in GiD 11 and 12.
I think the problem is in font changing but not sure.
Here is the screenshot with options from GiD 11:
