I have an active license for GiD 17. I can use it in Windows. When I try to login in another pc with Linux, I have this message:
(Login) Unknown error ‘couldn’t load file “scripts/verifp/verifp_64.so”: scripts/verifp/verifp_64.so: cannot open shared object file: No such file or directory’
Update:
I restarted and the problem was solved
What is the 17 exact GiD version? (see Help->About GiD…)
Which type of licence? (usb, floating, user-named login,…)
Please verify if really exists the file /scripts/verifp/verifp_64.so
if it exists then maybe cannot be loaded because some of its dependencies is missing in your OS, or the compilation is incompatible with your Linux
Which exact Linux?
