Hi all,
I tried installing GiD using the .tar.xz file unfortunately after unpacking it I get an error in terminal stating: gid16.0.5-x64/gid.exe: error while loading shared libraries: libzstd.so.1: cannot open shared object file: No such file or directory
Therefore I cannot start GiD. This happens when I try to run gid with the ‘gid’ or ‘./gid’ command as stated in the README.txt file within the installation files.
After checking the lib folder I see that said library is not present. My guess is that the error happens because the library is missing in the installation file.
The same happened with the -Install file.
How can I solve this issue? Is this version related? Should I just use an older version of GiD?
OS: Linux
GiD Version & installer: gid16.0.5-linux-x64.tar.xz
Terminal command: tar -xvf gid16.0.5-linux-x64.tar.xz
The Linux Distribution is: Red Hat Enterprise Linux Release 7
Release: 7.9
I tried the gid16.1.5d version (also with the .tar.xz file) but it also didn’t work. I got the following error:
/gid/gid16.1.5d-x64/gid.exe: /lib64/libc.so.6: version GLIBC_2.18' not found (required by <directory>/gid/gid16.1.5d-x64/lib/gcc_libs/libstdc++.so.6) <directory>/gid/gid16.1.5d-x64/gid.exe: /lib64/libc.so.6: version GLIBC_2.18’ not found (required by /gid/gid16.1.5d-x64/lib/gcc_libs/libstdc++.so.6)
GiD exited with error code = 1 != 0
Starting GiD Safe Mode
/gid/gid16.1.5d-x64/gid.exe: /lib64/libc.so.6: version `GLIBC_2.18’ not found (required by /gid/gid16.1.5d-x64/lib/gcc_libs/libstdc++.so.6)
Hi Miguel,
Thanks, I can try that developer version and see if it works.
I found that version 16.0.1 worked fine, I was able to open GiD.
For versions 16.0.4, 16.0.3, 16.0.2 I get a similar but different error: gid.exe: /lib64/libc.so.6: version `GLIBC_2.18’ not found (required by /gid/gid16.0.4-x64/lib/gcc_libs/libstdc++.so.6)
Not sure if the issue was specific to my system, distro or some bug in the installation files but at least an earlier version did work.
Let me know if I should communicate it somewhere else in case it helps.
Hi JuanCarlos,
we changed the compilation and packaging Linux system from our old Scientific Linux 7.4 to a more modern Ubuntu 16.0.4 and GiD version 16.0.1 was the last version compiled on SL 7.4.
That is why gid requires support for a newer GLIBC_XXX version than the one provided by SL7 or RH7.
Hi Miguel,
Understood, thanks for the insight.
I tried the developer version 16.1.5d from the link provided and it also worked on my system. Thank you very much.
Best,
Unfortunately Linux has drawbacks related with the binary compatibility of a compiled program, it is not possible to do a single compilation able to run in all distros.
Depending on your operating system maybe you can run other compiled versions.
Please, provide more information of your case.
What is your exact operating system?
It print some error message when running .gid in a console?
in case of OpenGL graphic problems try also to run .gidx
