I am making a structured mesh around an airfoil. I am using the number of divisions on the lines and I also concatenate them. If I want to change the number of divisions, I have to assign the structured mesh again to the surfaces. The same goes for concatenation, in which case I need to select the lines again. Is there a way to access all the assigned mesh properties and change the parameters directly? For example, a text block or file that has the number of divisions and I can simply update the number there and remesh?
Thanks.
