Graph
I have to result set, one for stress and one for displacement.
I would like to plot the graph of a point with the X axis being the displacement whilst the Y would be the stess. Right now, when I use Point Graph I can plot, say, X direction as Stress in X and Y direction as stress in Y but I cannot choose a different result set for the X axis and the Y axis.. Thanks for the help^!
The ‘point graph’ result could use different results for x and y axis,
but both results must belong to the current Analysis and time step
(open for example our model /examples/cajon2d.gid)
Maybe your results are defined for different ‘analysis’ ?
If results are written by your own code consider to set the same analysis name
I don’t think this is possible. I have one result for streess (vector on Gauss point) and one for displacement (vector on node).
I found a way out thought; I just export the data in Excel then I plot it there.
This, and a way to plot the value of the isoline directly on the isoline could be very nice update for the next version. Good day.
in your case it is not possible nowadays because a result is defined on nodes, and the other result on gauss points of the elements.
both results must be defined on the same support.
