Hi Jorge,
Your new version of GiDpost solved most of the problems. My example now runs with one group for ASCII and binary output and I can open the output with GiD.
I have now extended the example to two groups with different meshes (original triangles in the first mesh and one q2 element in the second mesh). See the following code.
#include <stdlib.h>
#include <stdio.h>
#include "gidpost.h"
#define ASCII_FORMAT
typedef struct {
int id;
float x, y, z;
} SCoord;
typedef struct {
int id;
int n1, n2, n3;
} SElem;
SCoord nodes[9];
SElem elems[8];
void GenMesh()
int i, j, idx;
SCoord * node;
SElem * elm1, * elm2;
idx = 1;
for ( i = 0; i < 3; i++ ) {
for ( j = 0; j < 3; j++, idx++ ) {
node = nodes + idx -1;
node->id = idx;
node->x = (float)(i);
node->y = (float)(j);
node->z = 0;
idx = 0;
for ( i = 0; i < 2; i++ ) {
for ( j = 0; j < 2; j++, idx+=2 ) {
elm1 = elems + idx;
elm2 = elm1 + 1;
elm1->id = idx+1;
elm1->n1 = i*3 + j + 1;
elm1->n3 = i*3 + j + 1 + 3 ;
elm1->n2 = elm1->n3 + 1;
elm2->id = idx+2;
elm2->n1 = elm1->n1;
elm2->n2 = elm1->n1 + 1;
elm2->n3 = elm1->n2;
float Random()
return rand()/(float)(RAND_MAX);
int main()
int i;
SCoord * node;
SElem * elm;
int elmi[4];
int elmi2[10];
GiD_FILE fdm, fdr;
GenMesh();
GiD_PostInit();
#if defined(ASCII_FORMAT)
fdm = GiD_fOpenPostMeshFile( "test_fd.post.msh", GiD_PostAscii);
fdr = GiD_fOpenPostResultFile( "test_fd.post.res", GiD_PostAscii);
#else
fdm = fdr = GiD_fOpenPostResultFile( "test_fd.post.bin", GiD_PostBinary);
#endif
/* write mesh for first time step */
GiD_fBeginMeshGroup(fdm, "Mesh 1");
GiD_fBeginMeshColor(fdm, "TestMsh", GiD_2D, GiD_Triangle, 3, 0, 0.99, 0);
/* coordinates */
GiD_fBeginCoordinates(fdm);
for ( i = 0; i < 9; i++ ) {
node = nodes + i;
GiD_fWriteCoordinates(fdm, node->id, node->x, node->y, node->z );
GiD_fEndCoordinates(fdm);
/* elements */
GiD_fBeginElements(fdm);
for ( i = 0; i < 8; i++ ) {
elm = elems + i;
elmi[0] = elm->n1;
elmi[1] = elm->n2;
elmi[2] = elm->n3;
elmi[3] = 2;
GiD_fWriteElementMat(fdm, elm->id, elmi);
GiD_fEndElements(fdm);
GiD_fEndMesh(fdm);
GiD_fEndMeshGroup(fdm);
/* write mesh for second time step */
GiD_fBeginMeshGroup(fdm, "Mesh 2");
GiD_fBeginMeshColor(fdm, "TestMsh", GiD_2D, GiD_Quadrilateral, 9, 0, 0.99, 0);
/* coordinates */
node = nodes + i;
/* elements */
elmi2[0] = 1;
elmi2[1] = 7;
elmi2[2] = 9;
elmi2[3] = 3;
elmi2[4] = 4;
elmi2[5] = 8;
elmi2[6] = 6;
elmi2[7] = 2;
elmi2[8] = 5;
elmi2[9] = 2;
GiD_fWriteElementMat(fdm, 1, elmi2);
GiD_fEndMesh(fdm);
/* now results for first time step */
GiD_fBeginOnMeshGroup(fdr, "Mesh 1");
GiD_fBeginResult(fdr, "EscalarNodos", "Analysis", 1.0, GiD_Scalar, GiD_OnNodes, NULL, NULL, 0, NULL);
GiD_fWriteScalar(fdr, nodes[i].id, Random());
GiD_fEndResult(fdr);
GiD_fEndOnMeshGroup(fdr);
/* now results for second time step */
GiD_fBeginOnMeshGroup(fdr, "Mesh 2");
GiD_fBeginResult(fdr, "EscalarNodos", "Analysis", 2.0, GiD_Scalar, GiD_OnNodes, NULL, NULL, 0, NULL);
// Close file(s)
#ifdef ASCII_FORMAT
GiD_fClosePostMeshFile(fdm);
#endif
GiD_fClosePostResultFile(fdr);
GiD_PostDone();
printf("Finished normally!!");
return 0;
This also runs for ASCII and binary output, but I can only open the ASCII output in GiD. The msh- and res-files also look like expected.
When I open the binary file with GiD 12.0 the geometry is shown, and in the message lines it says “Results read (binary format).”, but in the menu “View results” it say “Please load a MODEL first” everywhere.
Malte
