[ GiDlist ]
Sorry If I did not pose the question well.
Basically I am trying to setup a problem type to
create a .dat file which my solver can read.
The solver requires the value of the conditions
applied to the nodes of an element to be listed in the
.dat file.
Like this
NORMALFLUX 9 -6.000E+03 -6.000E+03 -6.000E+03
12 -6.000E+03 -6.000E+03 -6.000E+03
But I am having problems setting up the .bas file to
do this.
I can get GID to create a dat file listing the
elements and nodes, but I need the conditions on the
nodes of the element. How can I setup the .Bas file to
do this?
Peter Adey.
— Enrique Escolano escolano at cimne.upc.es wrote:
I do not understand the question well.
To show the conditions, you can directly select the
draw button in the
condition window.
Please, it specifies a little plus its question.
Sent: Tuesday, July 31, 2001 10:35 AM
Hi
I want to be to setup a problemtype .bas file to
display the conditions on the nodes of an element.
Therefore, to create something like this.
NORMALFLUX 9 -6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
NORMALFLUX 12 -5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
Many thanks,
Peter Adey
Do You Yahoo!?
Make international calls for as low as $.04/minute
with Yahoo! Messenger
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
To create a probleme type, you must create a group of configuration files: .prb,.cnd,*.bas, etc.
See the web page of gid to download a ProblemType creation tutorial:
http://gid.cimne.upc.es/support/index.html
It seems that in your sample the type of used element is the 9 nodes Quadrilateral.
If all the nodes of a element have the same condition value, then apply the condition over body elems (not over nodes)
and repeat the value for the 9 nodes.
for example, the file “problemtype”.cnd contain a condition some
NUMBER: 1 CONDITION: Normal_Flux
CONDTYPE: over surfaces
CONDMESHTYPE: over body elems
QUESTION: Flux_Value
VALUE: 0
END CONDITION
and the file “problemtype”.bas for example is
NORMALFLUX *
*Set Cond Normal_Flux *elems
*loop elems *OnlyInCond
*ElemsNum *
*Cond(Flux_Value) *Cond(Flux_Value) *Cond(Flux_Value)
*end elems
If each node have a different condition value, then apply the condition over nodes
and search the i-node of the element inside a loop over the nodes wiht the condition
“problemtype”.cnd
CONDMESHTYPE: over nodes
VALUE: 0
END CONDITION
“problemtype”.bas
NORMALFLUX
*loop elems
ElemsNum
*set var cont=0
*for(i=1;i=nnode;i=i+1)
*set var inode=ElemsConec(*i,int)
*Set Cond Normal_Flux *nodes
*loop nodes *OnlyInCond
*if(NodesNum==inode)
Cond(Flux_Value)
*break
*endif
*end nodes
*if(cont==2)
*if(innode)
*endif
*set var cont=0
*else
*set var cont=operation(cont+1)
*endif
*end for
*end elems
It is attached a small problemtype named Peter.gid (with the second sample code)
Sent: Wednesday, August 01, 2001 10:54 AM
Subject: Re: [ GiDlist ]
.dat file.
Like this
do this.
do this?
Peter Adey.
draw button in the
condition window.
Hi
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-6.0000000E+03
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
-5.0000000E+04
Many thanks,
Peter Adey
Do You Yahoo!?
Do You Yahoo!?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010801/ca1efea2/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010801/ca1efea2/attachment.bin
