Dear everyone:
I meet a problem when I calculate with GID6.30b.I put following lines in *.bat file: @ECHO OFF
rem OutputFile: 2\1.chk
3\code.exe 2\1
when I press start button in calculat windows,I was told “File writen OK” in state line of GID,but I cann’t get the result of calculation.
Moveover,if I input follow line in MS-DOS:
code.exe filename
everything is ok and I can get result. I don’t know why I cann’t calculate in GID. Could you tell me the reason?
Hi
I think you have problem with your .batch file if
you try to run inside GiD by pressing button
“Calculate”.
Cheers!!
— ţ־ΰ nzwyc at 163.net wrote: Dear everyone: I meet a problem when I calculate with GID6.30b.I put following lines in *.bat file: @ECHO OFF rem OutputFile: 2\1.chk 3\code.exe 2\1 when I press start button in calculat windows,I was told “File writen OK” in state line of GID,but I cann’t get the result of calculation. Moveover,if I input follow line in MS-DOS: code.exe filename everything is ok and I can get result. I don’t know why I cann’t calculate in GID. Could you tell me the reason? my best wishes to you!!
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
