Answered my own question. The problem can be rectified by changing the
following lines in the VRMLout.bas file:
geometry
*if(I==1)
IndexedFaceSet {
*else
To:
geometry
*if(I==1)
IndexedFaceSet {
solid FALSE
*else
The solid FALSE shows both faces of the triangle elements so it doesn’t
matter what way round they are.
My vrml viewer does not like files zipped with pkzip so use gzip instead
http://www.gzip.org/ and modify the bat file to contain the line (put
gzip.exe in the VRML problem type directory)
%3\gzip.exe -c %1.wrl %1.wrz
Mark
-----Original Message-----
Sent: 29 April 2002 22:44
Subject: Re: [GiDlist] VRMLout and GiD6.3.0b
The VRML viewers only show the front face of the triangles, but not the back
face.
In GiD, you can swap group surface normals to force a desired orientation,
but if it is
desired view front and back it is necessary write two repeated triangles
with opposite normals?
I’ unknow the VRML order to show the thwo faces.
Sent: Monday, April 29, 2002 6:51 PM
Subject: [GiDlist] VRMLout and GiD6.3.0b
Dear GiDteam.
I downloaded the recent course notes and installed the VRMLout problem
type
but it seems that GiD orders the nodes of triangular elements in a way
which
is not 100% vrml IndexedFaceSet compatible (some elements appear
invisible) swapping the node ordering on certain elements solves the
problem.
I realise that the VRMLout was only an example problem type but any
suggestions about element renumbering would be helpful.
Mark
+44 (0)1480302100
http://www.linx.co.uk/
person.
