[GiDlist] Use 3 GB physical RAM on Windows XP
Good morning
Thank for tour support.
I tried to apply the trick you proposed for use 3 GB of physical RAM on
Windows XP, but I have a problem. There is not a folder in C/program files
called Microsoft Visual Studio.
Any idea?
Check the Windows “Task manager” to see how much RAM is spending GiD.
On Windows x32 if the gid.exe process spend as you said 2 GB (of RAM, not
of
file size, files are usually compressed) it will crash
If do you have XP x32 an more than 2GB of physical RAM, could try to use
until 3GB by process with this trick:
_http://www.gidhome.com/support_team/faq_toc/faq40.html#GiD%20and%20the%20Operating%20SystemHow%20to%20make%20GiD%20use%20more%20than%202GB%20on%20Windows%20XP?_
If your results are so big, maybe you need a 64 bits version of GiD and
more
physical RAM
Probably you can write less results or less time steps in your results
file
to be able to handle them.
Fernando Salazar González
CIMNE
Avda. Doctor Arce, 14. 28002 Madrid.
Tel. +34 917 610 274
Móvil. +34 610 234 477
Fax. +34 915 612 987
fsalazar at cimne.upc.edu
www.cimne.com
AVISO IMPORTANTE
AVÍS IMPORTANT
registraran en un fitxer per facilitar la gestió de les comunicacions del
CIMNE. Es poden exercir els drets d’accés, rectificació, cancel·lació i
oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n,
Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
deletion and objection by letter sent to CIMNE, Gran Capitán, Edificio
C1-Campus Norte UPC, 08034 Barcelona, Spain.
You don’t need to have Visual studio, GiD was already compiled with this
/LARGEADDREASSAWARE flag (from the version 7.5.x)
You only need to configure Windows XP in this way:
MS Windows XP should be configured by adding the flag /3G to the Boot.ini
file. To do this just open the Control panel, click on the System icon, on
the Advanced options panel, then press the Configuration button of the Start
and recuperation section. In this window click on the Edit button inside the
System start section and the Notepad will pop-up with the Boot.ini file
opened. In this file there should be a line like this:
multi(0)disk(0)rdisk(0)partition(1)WINDOWS=“Microsoft Windows XP
Professional” /fastdetect
just add the /3G flag at the end, like:
Professional” /fastdetect /3G
Now the file must be saved, and MS Windows restarted
Sent: Monday, March 30, 2009 9:50 AM
Subject: [GiDlist] Use 3 GB physical RAM on Windows XP
Good morning
Any idea?
of
more
physical RAM
file
CIMNE
www.cimne.com
AVISO IMPORTANTE
AVÍS IMPORTANT
IMPORTANT NOTICE
GiDlist at gid.cimne.upc.edu
Where it says ‘/3G’ should be ‘/3GB’, so the correct line would be:
Professional” /fastdetect /3GB
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
De: gidlist-admin at gid.cimne.upc.edu [mailto:gidlist-admin at gid.cimne.upc.edu]
En nombre de Enrique Escolano
Enviado el: lunes, 30 de marzo de 2009 11:15
Asunto: Re: [GiDlist] Use 3 GB physical RAM on Windows XP
Good morning
Any idea?
of
ws%20XP?
more
physical RAM
file
CIMNE
www.cimne.com
AVISO IMPORTANTE
AVÍS IMPORTANT
IMPORTANT NOTICE
Pleas, look at the following page:
http://www.gidhome.com/support_team/gid3gb/index.html
En nombre de miguel
Enviado el: martes, 31 de marzo de 2009 9:16
Asunto: RE: [GiDlist] Use 3 GB physical RAM on Windows XP
Miguel Pasenau
IMPORTANT NOTICE
Good morning
Any idea?
of
ws%20XP?
more
physical RAM
file
CIMNE
www.cimne.com
AVISO IMPORTANTE
AVÍS IMPORTANT
IMPORTANT NOTICE
