[ GiDlist ] Units
Hi Aldo,
if you write
QUESTION: Young’s_modulus_E:#UNITS#
VALUE: 2.1e11Pa
it should work
there have being some corrections regarding units field and units systems
and will be available in the next release, although you can try the last
beta in
ftp://gid.cimne.upc.es/pub/gid_adds
what release of GiD are you ussing?
best regards,
Jorge Suit
Aldo Ghisi wrote:
Hello everybody,
a problem in the problem customization.
I don’t know how to modify the unit field as indicated in the GiD manual
for the special fields.
If I only introduce the string #UNITS# after the property_name and the
unit, i.e. (in the file problem_name.mat)
VALUE: 2.1e11Pa
and then I set the problem data
Data-Problem type-problem_name
the GiD crashes (I specify that without the unit, i.e. in the usual form
VALUE: 2.1e11
it works!).
I used all other special fields and I found them excellent.
ALDO GHISI
Politecnico di Milano
Tel.: +39 02 2399 4218
Fax.: +39 02 2399 4220
Hi Jorge,
I use GiD 6.1.2, operating system Win2000 :frowning:
I will try with GiD 6.1.4b, thank you.
Aldo Ghisi
At 16.53 22/06/2001 +0200, you wrote:
Hi Aldo,
if you write
VALUE: 2.1e11Pa
it should work
beta in
_ftp://gid.cimne.upc.es/pub/gid_adds_
best regards,
Jorge Suit
Aldo Ghisi wrote:
Hello everybody,
VALUE: 2.1e11Pa
VALUE: 2.1e11
it works!).
ALDO GHISI
