[GiDlist] Undesired blank line generated for bas file
I have a problem with the output of bas file, it generates a blank line betwen two data sets, I have checked my code but I haven´t found the error, I hope that somebody could help me.
– This is a part of the bas file (complete file attached) –
*# more bas file up
*# NODOS
*set elems(all)
*Set Cond Restricion_en_Volumenes *nodes *or(1,int) *or(3,int)
*Add Cond Restricion_en_Superficies *nodes *or(1,int) *or(3,int)
*Add Cond Restricion_en_Lineas *nodes *or(1,int) *or(3,int)
*Add Cond Restricion_en_Nodos *nodes *or(1,int) *or(3,int)
*loop nodes
*format “%10.3f%10.3f%10.3f%2i%2i%2i%2i%2i%2i”
*NodesCoord *cond(1) *cond(2) *cond(3) *cond(4) *cond(5) *cond(6)
*end
*# CARGAS
*Set Cond Puntual_X nodes
*loop nodes OnlyInCond
*format “%5i%3i%10.3f”
NodesNum 1cond(2)*cond(1)
*end
*Set Cond Puntual_Y nodes
NodesNum 2cond(2)*cond(1)
*end
*Set Cond Puntual_Z nodes
NodesNum 3cond(2)*cond(1)
*end
*# more bas file down
– I get a DAT file with a “undesired empty line” (complete file attached) –
more dat file up
64.000 16.667 55.000 1 0 0 1 1 1
55.667 0.000 50.000 0 1 0 1 1 1
64.000 8.333 50.000 1 0 0 1 1 1
55.667 0.000 55.000 0 1 0 1 1 1
64.000 8.333 55.000 1 0 0 1 1 1
64.000 0.000 50.000 1 1 0 1 1 1
64.000 0.000 55.000 1 1 0 1 1 1
354 3 4 -20.000
373 3 4 -20.000
380 3 4 -20.000
389 3 4 -20.000
394 3 4 -20.000
402 3 4 -20.000
404 3 4 -20.000
more dat file down
I attached the ProblemType (test_3d.gid) and a GiD file (gamma.dat)
Thanks in advanced.
Alejo J. Ch.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020713/9c19946a/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020713/9c19946a/attachment.bin
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020713/9c19946a/attachment-0001.bin
This is a bug of GiD in this case (related with a conditions cache):
*set cond A
*add cond B
*set cond A
Avoid the use of add cond in this case until this bug is corrected.
Another comment:
The material fields of the sample are different as the material fields of the problem type attached.
Ypu can use Data-ProblemType-Transform to update a sample to a new problemtype version.
Sent: Saturday, July 13, 2002 9:07 PM
Subject: [GiDlist] Undesired blank line generated for bas file
*# more bas file up
*# NODOS
*set elems(all)
*loop nodes
*end
*# CARGAS
*end
*end
*end
more dat file up
354 3 4 -20.000
373 3 4 -20.000
380 3 4 -20.000
389 3 4 -20.000
394 3 4 -20.000
402 3 4 -20.000
404 3 4 -20.000
more dat file down
Thanks in advanced.
Alejo J. Ch.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020715/e568983d/attachment.htm
