Hello GID people,
I am trying desperately to mesh a simple rectangle volume (100653.18)
using Tetrahedral of mesh size 0.5.
Can you please help me in meshing this structure.
Khaled
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040429/0aaab0f8/attachment.htm
Type: application/zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040429/0aaab0f8/attachment.zip
You are trying to mesh the model with “only points”, instead of
tetrahedra. Try to
use: Meshing-Elemtype-Tetrahedra and apply it to the volume.
http://www.compassis.com http://www.compassis.com/
ramsan at compassis.com
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Khaled Obeidat
Enviado el: miércoles, 28 de abril de 2004 22:52
Asunto: [GiDlist] Un able to mesh
Hello GID people,
Khaled
Khaled Obeidat
Research Engineer
www.emagtechnologies.com http://www.emagtechnologies.com/
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040429/ca23d2d9/attachment.htm
I did that but it didn’t work.
tetrahedra. Try to
http://www.compassis.com/http://www.compassis.com ramsan at compassis.com
Hello GID people,
Khaled
Khaled Obeidat
Research Engineer
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040430/49c488aa/attachment.htm
I tried it and it worked for me. How much memory do you have in your
computer? As the mesh size is quite small, I would recommend at least
512Mb of RAM.
Enviado el: viernes, 30 de abril de 2004 13:52
Asunto: RE: [GiDlist] Un able to mesh
tetrahedra. Try to
Hello GID people,
Khaled
Khaled Obeidat
Research Engineer
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040430/ee741538/attachment.htm
