I have been running the tutorial with some success, but I have been having a
few problems with errors about files not being found. First it was just the
help files, but this was not a serious problem. Now when I try to run the
calculations for the RamSeries4 module I am getting the message:
“Problem type ‘RamSeries4/ramsolid’ can’t be found”
When I open the Help file I get the message:
“couldn’t open ‘../GID/info/html-version/
../GID/info/html-version/intro/intro.html’: no such file or directory”
/GID/ is the directory I created to put my copy of GiD in. What is going
wrong? Where can I make the adjustments so that my files can be found?
My system is Linux Red Hat 7.3 with the 2.4.18-10 kernel
Paul Pikowsky, pksky at finestplanet.com
inside the directory GID must be located gid.exe and other files, and this
directories tree:
GID
|–bitmaps
|–Examples
|–info
| |—html-version
|–problemtypes
| |—RamSeries4
| | |----rambshell
| | |----ramsolid
| |------other problem types …
|–scripts
|–symbols
|–templates
Note: you must copy the problemtype RamSeries4 inside /problemtypes:
Sent: Wednesday, September 18, 2002 5:21 AM
Subject: [GiDlist] Tutorial: On calculate I get message “Problem type
a
the
"couldn’t open '../GID/info/html-version/
../GID/info/html-version/intro/intro.html’: no such file or directory"
To have RamSolid installed, just try:
Data-Problemtypes-Internet retrieve-RamSeries (inside GiD)
You can retrieve an automatic test password in: http://www.compassis.com
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Enrique Escolano
Enviado el: miércoles, 18 de septiembre de 2002 21:09
Asunto: Re: [GiDlist] Tutorial: On calculate I get message “Problem type
directories tree:
GID
|–bitmaps
|–Examples
|–info
| |—html-version
|–problemtypes
| |—RamSeries4
| | |----rambshell
| | |----ramsolid
|–scripts
|–symbols
|–templates
a
the
