Oleg,
I also have noticed and reported mesh errors with quadratic triangular
elements, the problem I have found has only occurred with mesh settings
RFast under utilities -preferences. I have seen no errors using RSurf.
Hope this helps.
Mark
-----Original Message-----
Sent: 12 August 2002 18:12
Subject: [GiDlist] Troubles with quadratic elemnt type mesh!!!
Importance: High
Hello All,
We bought 6.* version of GID, and use GID 6.3-beta version (This problems
appears in GID 6.1.2 and GID 7.0.1). Sometimes, this version generates wrong
mesh (see attached file new.msh, nodes # 46 and 55).
Those middle nodes of quadratic triangular elements are situated not on the
middle of edges, where they should be (the same happens with quadratic
quadrilateral elements). So we have some problem with it.
Oleg mailto:oleg2205 at mail.ru
+44 (0)1480302100
http://www.linx.co.uk/
person.
Name: Mark Smith (E-mail).vcf
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020813/2f9da8fc/attachment.obj
