[ GiDlist ] troubles with meshview
Dear Pablo,
In general in GEOSTAR you can plot “faster” shaded Shell elements mesh without geometry associated, but the hidden line algorithm is not always successful in plotting the elements correctly, especially for 3D solid models (Bricks & Tetras), so different techniques can be used to correct the displays.
Yesterday I explained “to remove geometry association” of the elements during the plotting process, but also the z-buffer algorithm (Display Display_Option Set Hide Option) will usually do the trick of correcting the hidden line plot. The z-buffer algorithm is more robust but is much more CPU intensive and can take relatively long times for display especially for large models.
The z-buffer algorithm along with the removal of geometry will always solve any plotting problems for 3D solid elements !!
Cheers!,
Blas.
Blas Molero Hidalgo
Director
Tecnologías CAE Avanzadas, S.L.
Parque Tecnológico de Zamudio - Edificio Central, nº 101
48170 Zamudio (SPAIN)
Tel.	+34 94 420 93 54
Fax. 	+34 94 420 93 55
E-mail:	[Blas.molero at tecnocae.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
WEB:	http://www.tecnocae.es
Desde: 	Pablo Perez del Castillo
Enviado el: 	viernes 26 de enero de 2001 3:42
Para: 	[gidlist at gatxan.cimne.upc.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Asunto: 	Re: [ GiDlist ] troubles with meshview
Thanks Blas, i will try, with shell elements export without geometry i never have troubles.
Pablo
=?iso-8859-1?Q?Blas_Molero_=2D_Tecnolog=EDas_CAE_Avanzadas?= escribió:
_Dear Pablo,_
_In COSMOS/M Geostar you don´t see anything when plotting elements because the mesh is not associated to geometry, the information you can import from GiD is only nodes & elements, not the geometry (Curves, Surfaces, etc..)._
_You can display mesh simply issuing the following commands:_
_. "BOUNDARY,1,0" command from "Display, Display_Option, Set Bound Plot" to plot boundary element faces only not associated with a surface or region_
_. "EVAL_BOUND,1,0,20,1" command from "Display  Display_Option  Eval Element Bound" to evaluate boundary faces,_
_. "SHADE;" command to activate shading of element plots, and finaly_
_. "EPLOT;" command to plot ALL elements._
_You have this problem well explained in our COSMOS/M Support page in the following address:_
_http://www.tecnocae.es/soporte/cosmosm/display.htm_
_Best regards,_
_Blas._
_~~~~~~~~~~~~~~~~~~~~~~_
_Blas Molero Hidalgo_
_Director_
_Tecnologías CAE Avanzadas, S.L._
_Parque Tecnológico de Zamudio - Edificio Central, nº 101_
_48170 Zamudio (SPAIN)_
_Tel.    +34 94 420 93 54_
_Fax.    +34 94 420 93 55_
_E-mail: [Blas.molero at tecnocae.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_WEB:    http://www.tecnocae.es_
_----------_
_Desde:  Pablo Perez del Castillo_
_Enviado el:     jueves 25 de enero de 2001 3:31_
_Para:   [gidlist at gatxan.cimne.upc.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_Asunto:         [ GiDlist ] troubles with meshview_
_Hi to everybody_
_When i generate tetrahedra elements, then meshview does not work, so i can see_
_the mesh in normal mode, but when i do render filled nothing to see, and when i_
_export to cosmos it happens the same, i can see the mesh with no hidden, when i_
_try to render, nothing to see._
_Anybody can help me ._
_advanced thanks_
_------------------------------------------------------------------------_
_Part 1.2    Type: application/ms-tnef_
_Encoding: base64_
Name: not available
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010126/622e662a/attachment.bin
