[ GiDlist ] troubles with generate mesh
I had impoted IGES, so i need to generate mesh with triangle(surfaces) and tetrahedra(volume), GID generates shell in surface, but not for
volume. Anybody to help me ??
Advanced thanks
To generate tetrahedra mesh, first a volume must be created whith the
boundary surfaces.
If the mesh generation fail, you can send the IGES file to
escolano at cimne.upc.es to check it.
best regards
Sent: Tuesday, January 09, 2001 4:08 AM
Subject: [ GiDlist ] troubles with generate mesh
Advanced thanks
Hi to everybody
When i generate tetrahedra elements, then meshview does not work, so i can see
the mesh in normal mode, but when i do render filled nothing to see, and when i
export to cosmos it happens the same, i can see the mesh with no hidden, when i
try to render, nothing to see.
Anybody can help me .
advanced thanks
