[ GiDlist ] Surface connectivities?
Is it possible to alter the sense of the element connectivites within Gid??
I running some contact problems and hence need the surface element connectivities for the contact input. The output which Gid is giving is opposite to the direction I require.
Can this be altered within a “*Set Cond” statement where i am looping over the face elements using “*GlobalNodes” for the surface connectivities??
Obviously, I could alter the format in the FE code, but i would like keep the code in its original format.
Thanks in advance,
Matthew
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010430/b6a9f004/attachment.htm
