[GiDlist] Showing graph labels in ver 7.4.9b
Hello
When I plot more than one graph in version 7.4.9b there is problem with
getting graphs labels. If I have two or more graphs, it is only possible to
select points to show their labels in the first graph drawn. The other
graphs are ignored if the view_label_select – command is used.
/BF
Billy Fälth
Clay Technology AB
Ideon Research Center
S 223 70 Lund, SWEDEN
Tel +46 46 286 25 81
Fax +46 46 13 42 30
www.claytech.se http://www.claytech.se/
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040816/5b5a6b3d/attachment.htm
Thanks for this bug report.
In other hand, you can show all graph point results with: Label-All in-Results
Sent: Monday, August 16, 2004 11:41 AM
Subject: [GiDlist] Showing graph labels in ver 7.4.9b
Hello
When I plot more than one graph in version 7.4.9b there is problem with getting graphs labels. If I have two or more graphs, it is only possible to select points to show their labels in the first graph drawn. The other graphs are ignored if the view_label_select - command is used.
/BF
Billy Fälth
Clay Technology AB
Fax +46 46 13 42 30
www.claytech.se
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040906/2b1170d5/attachment.htm
