[GiDlist] Several problem
Hi everyone,
when i try to open, in a postprocessing contest, a file “myfile.msh” a info
window appears in which is written: “too few parameters:in this line: 7-
Reading mesh”.
What does it mean?
What should i do?
And also, i have always the same problem with gid.exe error; now in postprocessing
too. It happens when i push every option in “view results”.
Calogero
it means that there is an error the the file, and it can not be read.
is the file is written in GiD postprocess format?
look at http://www.gidhome.com/support/gid_16.subst#SEC237
can you post the file?
Do the gid.exe error still appear when you change to 256 colors?
Have you tried to select the ‘GiD safe mode’ menu entry, inside
the window’s Start menu-Programs-GiD…-GiD safe mode; and then
have you choosen the 'Yes, i’m experiencing troubles with my card and
want to use the software OpenGL?
Have you tried upgrading your graphic card drivers?
Which graphic card does your notebook have
(Controlpanel-Display-Setting-Advanced options-adaptor) ?
best regards
kalo81 at virgilio.it wrote:
Hi everyone,
window appears in which is written: "too few parameters:in this line: 7-
Reading mesh".
What does it mean?
What should i do?
Calogero
