[GiDlist] results on gauss points for tetrahedras .
you’re right, Kenji Furui, the smoothed results of the first face
of the tetrahedra are repeated onto the other three ones. This
is a bug, and will be corrected in the next version.
The same happens to hexahedras.
Subject: Re: [GiDlist] results on gauss points for tetrahedras .
Date: Fri, 6 Sep 2002 18:15:14 +0200
It seems a bug of GiD postprocessing results on tetrahedrals with 4 gauss
points.
Use until a corrected version only 1 gauss point or extrapolate with your
code the results to the nodes
Thanks by your bug report.
Enrique Escolano.
Sent: Friday, September 06, 2002 3:07 PM
Dear Enrique,
This is the simple example.
Please take a look at all faces of the tetrahedra.
One of the face shows the bug.
thanks,
kenji
— Enrique Escolano escolano at cimne.upc.es wrote:
Please, send us the complete files .flavia.res and
.flavia.msh
(or all the GiD model files if not exist this
.flavia.msh)
Specify also as it is the GiD version used.
Sent: Friday, September 06, 2002 12:18 AM
Subject: [GiDlist] results on gauss points for
tetrahedras .
Dear GID members,
I think there is a problem when we visualize
results on gauss points(4pts) for quadratic
tetrahedral elements.
Example:
in res file.
GaussPoints “Gauss” ElemType Tetrahedra
Number Of Gauss Points: 4
Natural Coordinates: Internal
End Gausspoints
RESULT “Pressure Profile” “SimpleCase” 1 Scalar
OnGaussPoints “Gauss”
Values
1 1.0
1.0
0.0
1.0
End Values
Then you’ll see the bug in one of the faces of the
tetrahedra.
Does anybody have the same problem?
thanks,
kenji furui
The University of Texas at Austin
USA
Do You Yahoo!?
Yahoo! Finance - Get real-time stock quotes
http://finance.yahoo.com
Do You Yahoo!?
#MESH OF A TABLE
MESH "board " DIMENSION 3 ELEMTYPE Tetrahedra NNODE 4
COORDINATES
# node num x-coordinate y-coordinate z-coordinate
1 .100000000000E+01 .100000000000E+01
.000000000000E+00
2 .000000000000E+00 .100000000000E+01
.000000000000E+00
3 .100000000000E+01 .000000000000E+00
.000000000000E+00
4 .000000000000E+00 .100000000000E+01
.100000000000E+01
END COORDINATES
ELEMENTS
# elmnum nodal_connectivity() material
1 1 2 3 4 1
END ELEMENTS
GID POST RESULTS FILE 1.0
Natural Coordinates: Given
.585410 .138197 .138197
.138197 .138197 .585410
.138197 .585410 .138197
.138197 .138197 .138197
End Gausspoints
RESULT “Pressure Profile” “Completion Model” 1 Scalar OnGaussPoints
“Gauss”
Values
1 100.
100.
1.
100.
End Values
MSN. Más Útil cada Día. http://www.msn.es/intmap/
