Hello Gid users,
I’m attempting to mesh a simple cylinder, internal radius 100, external 110, height 300, with linear brick elements. (using Gid 6.1.2)
If I create a quarter of the cylinder and then use the copy option to produce the full cylinder I get problems when writing the mesh file using ‘Write Calculation File’ option. When I output the node numbers and corresponding cordinates, with boundary code, to a *.dat file certain nodal co-ordinates are repeated. This causes my FE code to crash in its initial stages.
I am using the canRepeat command in the *.bas file for surface pressures which are written later, so i assume this is not the problem.
I’m using the copy option with the quarter cylinder since you need six surfaces to use hexahedra elements. The in-built cylinder creator is only valid for 2D problems. Can anyone help me with this problem??
Thanks in advance,
Matthew Profit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020111/93cd2b60/attachment.htm
Have you tried Utilities – Collapse – Model after generating the mesh?
Hope it helps
El Vie 11 Ene 2002 06:07, escribió:
Hello Gid users,
stages.
Thanks in advance,
Matthew Profit
Jesús Torrecilla Pinero
Ingeniero de Caminos, Canales y Puertos.
Depto. Técnicas y Medios.
Universidad de Extremadura
In the copy window, Uncheck the option “Duplicate entities” to not create overlaped entities
or use Collapse of the geometry after copy entities
(If collapse the mesh is necessary to repeat this operation if remesh. In addition applied conditions can be destroyed)
Sent: Friday, January 11, 2002 6:07 AM
Subject: [GiDlist] repeated coordinates
Hello Gid users,
Thanks in advance,
Matthew Profit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020111/43743649/attachment.htm
