This is a known problem in Windows 2000. This is more a Windows problem
than a GiD problem because Win2000 permits a normal user to create a virtual
drive but not to delete it. GiD new version will init the calculation in a
different way in order to avoid this problem.
The workarounds are:
- Give the user administrator privileges. In this case, everything works
perfectly. - Continue working in the same way. The program will calculate correctly
but a couple of virtual units (f: g: h: …) will be left after
every calculation. When Windows is closed and open again, these virtual
units dissapear. It is also possible to delete them by hand.
Ramon Ribó
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de peter adey
Enviado el: jueves, 23 de agosto de 2001 16:59
Asunto:
Hi
I am running GID on Windows 2000. When I try to
preprocess and calculate a project a warning appears
“unsetdrive g: Access is denied”.
This occurs also when using the GID example
problemtypes supplied.
Many thanks,
Peter Adey
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
