[GiDlist] Re: [GiDlist] Re: [GiDlist] A&
Thanks,but I couldn’t get the sweep element at geometrical level,Can
you tell me the every step to do.Such as Can you tell me How can I get
prismatic elements at geometrical level.Thanks!
edodo
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
The first is to recommend you to use the copy (extrusion) at a geometrical
level, obtaining volumes from surfaces, and then meshing the resulting
volume. Try to avoid to use the copy window over the mesh, because you
highly complicate the application of conditions, materials, etc.
Nevertheless, if you prefer to extrude surface elements, and work with the
resulting volume element (prismatic elements if you originally use
triangular elements, or hexahedral elements if you use quadrilateral ones),
you can use them in the same way of any tridimensional meshing:
*loop elems
*ElemsNum *ElemsConec
*end elems
that will generate a list like:
1 1 2 4
2 6 5 3
3 3 1 4
4 3 4 6
5 13 14 16
6 18 17 15
7 15 13 16
8 15 16 18
9 1 2 4 13 14 16
10 6 5 3 18 17 15
11 3 1 4 15 13 16
12 3 4 6 15 16 18
for an original mesh of four triangles extruded to four prisms.
Note: is created also a moved copy of the original triangles: finally exist 8
triangles and 4 prisms
If you want to write just the prisms, you have to use:
*set elems(prisma)
*loop elems
*end elems
or delete the triangular elements (Meshing-Editg Mesh-Delete elements) and
filter with the Sel Window (secondary mouse button) to apply only over
triangles (Filter: Element Type; triangle).
Aufvidersen, Lucas
Sent: Thursday, August 29, 2002 2:54 AM
Subject: [GiDlist]
Re: [GiDlist] A question about Mesh
Thanks.
I have an other question,I find that we can translation surface element
to
body element,But I could’t get the same entities,Why? In other words how
can I
use the sweep element in Gid.
edodo
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
It is not available now in GiD the mesh import from Ansys.
Check if Ansys can export in Nastran format.
HI
How can I use the information of elements which I have meshed the
same
model
in other software.In other word,If I have used ANSYS to mesh the
model,Than I
want to use the information of elements to generate the same model in
gid
,and
I can get the same elements.
Yours edodo
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
At geometrical level is available the surface extrusion with the copy
utility
(Utilities-Copy, Entity type:surface, Do Extrude Volumes)
If the volume have 6 faces, it can be meshed structured with hexahedrals,
but it is not available to mesh with prisms (unstructured in a surface, and
structured in the extrusion direction)
Only is possible to create this prisms extruding directly the surface mesh,
but this mesh operation
only create the new prismatic elements, the geometry is not modified.
Sent: Tuesday, September 03, 2002 5:15 AM
Subject: [GiDlist]
Re: [GiDlist] Re: [GiDlist] A question about&n
bsp;Mesh
level,Can
edodo
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
geometrical
the
ones),
*loop elems
*end elems
1 1 2 4
2 6 5 3
3 3 1 4
4 3 4 6
5 13 14 16
6 18 17 15
7 15 13 16
8 15 16 18
9 1 2 4 13 14 16
10 6 5 3 18 17 15
11 3 1 4 15 13 16
12 3 4 6 15 16 18
exist 8
*set elems(prisma)
*loop elems
*end elems
and
Aufvidersen, Lucas
Subject: [GiDlist]
Thanks.
element
to
how
can I
edodo
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
HI
same
model
model,Than I
in
gid
,and
Yours edodo
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
