The first is to recommend you to use the copy (extrusion) at a geometrical
level, obtaining volumes from surfaces, and then meshing the resulting
volume. Try to avoid to use the copy window over the mesh, because you
highly complicate the application of conditions, materials, etc.
Nevertheless, if you prefer to extrude surface elements, and work with the
resulting volume element (prismatic elements if you originally use
triangular elements, or hexahedral elements if you use quadrilateral ones),
you can use them in the same way of any tridimensional meshing:
*loop elems
*ElemsNum *ElemsConec
*end elems
that will generate a list like:
1 1 2 4
2 6 5 3
3 3 1 4
4 3 4 6
5 13 14 16
6 18 17 15
7 15 13 16
8 15 16 18
9 1 2 4 13 14 16
10 6 5 3 18 17 15
11 3 1 4 15 13 16
12 3 4 6 15 16 18
for an original mesh of four triangles extruded to four prisms.
Note: is created also a moved copy of the original triangles: finally exist 8 triangles and 4 prisms
If you want to write just the prisms, you have to use:
*set elems(prisma)
*loop elems
*end elems
or delete the triangular elements (Meshing-Editg Mesh-Delete elements) and
filter with the Sel Window (secondary mouse button) to apply only over
triangles (Filter: Element Type; triangle).
Aufvidersen, Lucas
Sent: Thursday, August 29, 2002 2:54 AM
Subject: [GiDlist] Re: [GiDlist] A question about Mesh
Thanks.
I have an other question,I find that we can translation surface element to
body element,But I could’t get the same entities,Why? In other words how can I
use the sweep element in Gid.
edodo
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
It is not available now in GiD the mesh import from Ansys.
Check if Ansys can export in Nastran format.
HI
How can I use the information of elements which I have meshed the same
model
in other software.In other word,If I have used ANSYS to mesh the
model,Than I
want to use the information of elements to generate the same model in gid
,and
I can get the same elements.
Yours edodo
–http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020829/d426590a/attachment.htm
