[GiDlist] Re: [GiDlist] A bug about&nbsp
Hi:
There is the another copy of the .geo file
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
The compressed rar file is corrupted,
please send us another copy of the .geo file.
HI:
I find a bug in Gid.When I have created a PolyLine and extrude it to a
surface.Then if you will render it you will find a erro surface.I attched
an
example.
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020916/58e645d6/attachment.obj
This surface, generated extruding a polyline, have two internal edges, and
it is complicated to mesh.
It is possible to generate the mesh, but the nodes are not generated over
the edge (to render is
necessary also a special meshing)
Is is recommended to avoid surfaces with “internal edges”.
Note: if you collapse this model, the surface is divided automatically in
three parts.
Sent: Monday, September 16, 2002 3:45 AM
Subject: [GiDlist]
Re: [GiDlist] A bug about polyline
Hi:
ÔÚÄúµÄÀ´ÐÅÖÐÌáµ½
HI:
a
attched
an
example.
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
http://www.eyou.com
ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
Hi GiD Team
I’m modelling some Dam Structures but still confuse
with the GiD EXTRUDE command. If GiD can extrude from
different shape to another different size shape.
Please take a look the attached file. Please give your
advice how we use the extrude on this Dam shape.??
Do you Yahoo!?
Yahoo! News - Today’s headlines
Type: application/msword
Desc: DAM1.doc
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/bd29b761/attachment.doc
It is not possible to extrude from a shape to another shape, only is possible, for example, extrude a section
to another scaled section.
It is posible to extrude a point, a curve or a surface with a translation, a rotation, a scaled, a mirror a offset or a sweep along another curve
I do not understand with the elevation of your image, the final shape dam that you want create.
Sent: Wednesday, September 18, 2002 1:10 PM
Subject: [GiDlist] How GiD extrude the volume from different surface size
Hi GiD Team
Do you Yahoo!?
http://news.yahoo.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/045d3e9a/attachment.htm
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/045d3e9a/attachment.gif
Hi Enrique
Thanks for the reply. I’m very sure that GiD can
extrude my model, since you showed me your model. My
Dam model is an Arch Dam. The Dam is 30m high. The Top
arch of the Dam (53deg) is longer than the base
(20deg). How we extrude this two surfaces together.
Please see more figure I added.
With my best regards.
extrude a section
Hi GiD Team
confuse
from
your
Do you Yahoo!?
Yahoo! - We Remember
9-11: A tribute to the more than 3,000 lives lost
http://dir.remember.yahoo.com/tribute
Desc: Arch Dam.doc
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/6ff7368d/attachment.doc
This is a cilyndrical pipe part cutted by some plane
I’ attach this model:
This is the steps to construct it.
1- Create a line from (43.25,0) to (46.25.0)
2 -Create the surface base extruding this line whit a rotation 2D of 53º (center 0,0,0)
3- Create the rest of the pipe part, extruding this base with a translation 0,0,30, extruding only surfaces
4- Create two auxiliar points to define cut points on the base arcs, extruding the first two points rotating 20º
5- Divide the cilyndrical intersecting the surface, selecting two points of the cut wit
surfaces Create-Intersection-Two Points
6-collapse the model to avoid duplicated entities, and divide also the base surface
(Geometry-Edit-Divide-Surface-Neart Point)
7-create a new surface to divide in tho parts
8-Delete the unneeded surfaces, lines and points, create the volume, and this is the result:
Sent: Wednesday, September 18, 2002 7:41 PM
Subject: Re: [GiDlist] How GiD extrude the volume from different surface size
Hi Enrique
extrude a section
Hi GiD Team
confuse
from
your
Do you Yahoo!?
_http://dir.remember.yahoo.com/tribute_
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment.htm
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment.gif
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment-0001.gif
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment-0002.gif
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment-0003.gif
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment-0004.gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020918/136b58be/attachment.bin
Hi GiD team
Thanks Enrique for your advice about Extrude. Now
just would like to ask about the icon in GiD. I know
how to create the icon in GiD like ICons in Ramshell
or so on but I don’t know what software you use to
create it, Photoshop?. I have created but my Icons are
somehow strange in colors. Please give your advice.
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
You can use any program for image manipulation. Photoshop
is a good alternative. Another option is to use GIMP, that
is a very powerful open source program, available in both,
Windows and UNIX.
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de VSayako Willy
Enviado el: lunes, 23 de septiembre de 2002 4:11
Asunto: [GiDlist] Create ICON in GiD
Hi GiD team
Do you Yahoo!?
