Hi, we released GiD version 9 a couple of days ago. I recommend you use this
latest version.
Regarding your question, you can do an iso-surface of one or several values
of a result and using the colour of this value to differentiate them. A
legend is also shown with the correspondence between the colours and the
values. The option Options – Iso surfaces – Color Mode – Result
color should be selected.
Here are two examples, the first one with one value:
And the second one with five values:
If you are talking of showing the label of the value over the
isosurface/isoline, at the moment this is not possible, but we write it down
for future releases.
Thanks for the suggestion.
Miguel Pasenau
De: gidlist-owner at gid.cimne.upc.edu [mailto:gidlist-owner at gid.cimne.upc.edu]
En nombre de SC Sembenelli Consulting - Roma
Enviado el: jueves, 03 de julio de 2008 9:43
Para: gidlist-admin at gid.cimne.upc.edu
Asunto: Iso-Surface - value within the line
Hi dears,
Im using GID 8.0.9 to pre-processing and post-processing a Concrete Gravity
Dam model. Id like to know if is it possible to draw the iso-surface with
one colour and describe the value within the line (like the topographical
curves
TKS
Gianluca Gatto
Via Montasio, 31
00141 Roma
06 871 871 08
Questo documento, allegati inclusi, contiene informazioni di proprietà di SC
Sembenelli Consulting srl e deve essere utilizzato esclusivamente dal
destinatario in relazione alle finalità per le quali è stato ricevuto.E
vietata qualsiasi forma di riproduzione o di divulgazione senza lesplicito
consenso di SC Sembenelli Consulting srl (D.L.vo 196/2003 e successive
modifiche). Qualora fosse stato ricevuto per errore si prega di informare
tempestivamente il mittente e di distruggere la copia in proprio possesso.
This document, including attachments, is intended for the person(s) or
company named and may contain confidential and/or legally privileged
information. The information contained is property of SC Sembenelli
Consulting srl (Decree-Law 196/2003) . Unauthorised disclosure, copying or
use of this information is prohibited without the authorisation of SC
Sembenelli Consulting srl. If you are not the intended recipient, please
delete this message and notify the sender.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20080703/506d88de/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20080703/506d88de/attachment.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20080703/506d88de/attachment-0001.jpeg
