[ GiDlist ] RE: [ GiDlist ] Doubt about the nodes and elem
I was also interested in the following answer:
Hay un comando “renumber”, que puede ayudarte. Lee el manual bajo ese
título. El uso bajo la modalidad “geometry” puede servirte porque renumera
los nodos buscando minimizar la diferencia entre los números de nodo de cada
elemento.
Saludos
Alejandro Casares
But I can’t understand the Spanish one :slight_smile:
Is it possible to post the answer in English too?
Sebastian Skatulla
University of Karlruhe
Germany
He says that:
“There is a ‘renumber’ command, which can help you. Look in
the manual, under the same title. Its use under the ‘geometry’
modality can help you because it renumbers the nodes while trying
to minimize the difference between the node numbers of each element.”
You can look also here:
http://gid.cimne.upc.es/support under ‘On line manual - Utilities - Renumber’
or directly here:
http://gid.cimne.upc.es/support/gid_11.html#SEC142
Hope this helps,
About this question:
Hi Alex
I would also like to know how we can ask GID to number
the nodes the way we like.If possible write an english
reply as wel.
What kind of renumeration are you thinking about?
GiD only has one way to renumber nodes. It fills the
numeration holes and tries automatically to
minimize the half bandwidth, i.e. minimize the difference between
the node numbers of each element. So there is no posibility
to manually impose a numbering order to the nodes.
miguel and Enrique Escolano
elemento.
Saludos
Alejandro Casares
Sebastian Skatulla
Germany
The GiD command: UtilitiesRenumber does several things:
If GiD is in geometry visualization, it renumbers the geometrical
entities in order to
avoid holes in the numeration.
In mesh visualization, it does the same thing with the nodes and the
elements and it also
performs a simple algorithm that renumber the nodes in order to minimize the
difference of numbers
inside a mesh element. This is useful for different types of storage, like
skyline, in the solver
matrix.
Ramon Ribó
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de Sebastian Skatulla
Enviado el: martes, 17 de abril de 2001 3:23
Asunto: Re: [ GiDlist ] RE: [ GiDlist ] Doubt about the nodes and
element´s enumaration in GID
cada
elemento.
Saludos
Alejandro Casares
Sebastian Skatulla
Germany
