[GiDlist] Re: GiDlist digest, Vol 1 #414 - 1 msg
Thank you very much,
I do appreciate your repply and your effort.
I am working with GID in boundary elements methods (BEM).
This definition of gauss points ( a = 1/6, b = 2/3, c = 5/12, d = 1/6)
is very common in BEM, when using triangular discontinuous elements.
I believe that anyone working with BEM will really appreciate this
feature of GID.
best regards,
Andres
gidlist-request at gatxan.cimne.upc.es wrote:
gidlist at gid.cimne.upc.es
gidlist-request at gid.cimne.upc.es
gidlist-admin at gid.cimne.upc.es
Los envios para la lista de correo GiDlist han de enviarse a
Para subscribirse o desapuntarse via World Wide Web, visite
o, via email, enviando un mensaje con ‘help’ en el ‘asunto’ o ‘cuerpo’
a
Puede contactar con la persona que administra la lista bajo
Cuando responda, por favor, edite la linea del ‘asunto’ para que sea
más especifica que “Re: Contenido resumen de GiDlist …”
Today’s Topics:
1. Re: inaccurate postprocessing with given Gauss points (Miguel A. de Riera Pasenau)
Message: 1
Date: Tue, 01 Jul 2003 10:50:54 +0200
From: “Miguel A. de Riera Pasenau” miguel at cimne.upc.es
Organization: CIMNE ( UPC)
Subject: Re: [GiDlist] inaccurate postprocessing with given Gauss points
Yes, there was a problem with inverting a matrix when zeros appeared
on the diagonal. With 0.16667 there was no problem, but with 0.1666666666666666667.
i think i will prepare a new beta this week with this problem solved.
Andres Peratta wrote:
When postprocessing scalar results with “given” gauss points
I found out that the visualization becomes quite inaccurate.
For example Contour_fill and Contour_lines options, dont’ work properly.
It seems that the defined coordinates of the gauss points should not have
more than 5 decimal figures,
otherwise the given coordinates in the .res file are not read properly
by GID.
To see what is going on, you can try the following example in which
a scalar field
u(x,y) = x
is visualized in a single unitary triangular element with 6 gauss points
located at the following coordinates :
( a, a) ( b, a) ( a, b) ( c, d) ( c, c) ( d, c)
( see the attached .res file in which I used different precisions to
represent the fractional
numbers 1/6, 2/3 and 5/12 , and see what happens when contour_lines
or contour_fill options are selected )
The main problem is that if I want to increase the precision of the
given coordinates,
beyond 5 figures the result is completely unpredictable,
and if I keep 5 or less figures, the visualization does not reflect the
real scalar field.
Is there any solution ?
Has anyone faced this problem before ?
Thanks for your help.
best regards,
Andres
Andres B. Peratta
Wessex Institute of Technology
Email: andres at wessex.ac.uk
Tel: +44 (0)238 029 3223
Fax: +44 (0)238 029 2853
Ashurst Lodge
Ashurst
Southampton (SO40-7AA)
UK
Gid Post Results File 1.0
GaussPoints “gauss1” Elemtype Triangle
Number Of Gauss Points: 6
Natural Coordinates: Given
0.16667 0.16667
0.66667 0.16667
0.16667 0.66667
0.41667 0.16667
0.41667 0.41667
0.16667 0.41667
End GaussPoints
GaussPoints “gauss2” Elemtype Triangle
0.166666666667 0.166666666667
0.666666666667 0.166666666667
0.166666666667 0.666666666667
0.416666666667 0.166666666667
0.416666666667 0.416666666667
0.166666666667 0.416666666667
End GaussPoints
GaussPoints “gauss3” Elemtype Triangle
Natural Coordinates: Internal
End GaussPoints
Result “uf” “Convergency” 2.0000E+00 scalar OnGaussPoints “gauss1”
Values
1 0.16667
0.16667
0.66667
0.16667
0.41667
0.41667
End Values
Result “uf” “Convergency” 2.0000E+00 scalar OnGaussPoints “gauss2”
Values
1 0.16667
0.16667
0.66667
0.16667
0.41667
0.41667
End Values
Result “uf” “Convergency” 2.0000E+00 scalar OnGaussPoints “gauss3”
Values
1 0.16667
0.16667
0.66667
0.16667
0.41667
0.41667
End Values
testgp.geo Type: unspecified type (application/octet-stream)
Encoding: base64
testgp.msh Type: model/mesh
Encoding: quoted-printable
testgp.flavia.msh Type: model/mesh
Encoding: 7bit
Andres B. Peratta
PhD Student
Ashurst Lodge
Ashurst
UK
