[GiDlist] Re: create contact or intersection
Hi, GiD teams
I have a model in which two volume entities (with different material types) shared an exactly same interface surface. I want to make them share the same nodes at their interface surface after solid meshing. I have tried the creation of intersection or conatct, but not successful. Can someone give a suggestion and brief instructions on this problem?
Thank in advance!
Henry
Post your free ad now! Yahoo! Canada Personals
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050307/2adbffdd/attachment.htm
You don’t need contact or make interesections.
You must only create a single surface (not two copies), and select it for each volume boundary.
The geometric topology is refected in the mesh (if geometric entities are shared, then mesh entities are shared)
Sent: Monday, March 07, 2005 5:19 AM
Subject: [GiDlist] Re: create contact or intersection
Hi, GiD teams
Thank in advance!
Henry
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050307/3fb5ddcc/attachment.htm
