I have installed recently version 7.4.7b due to my
problem I have got.
I briefly describe the steps I am doing which lead to
the crash:
My program has calculated half of the system’s
deformation figure and has generated out of its
internal data the output files deformation.msh and
deformation.res. This is possible, because the
problem is symmetric and can be mirrored. I will send
both file as attachment.
I open the files in the postprocessing mode and can
now visualize half of the system’s deformed mesh.
Then I am going to mirror the figure in order to
make it whole with
utilities-copy
switch there on mirror and two dimensions
pick to corner nodes
change to create
and press “do it”
Then with version 7.4.7 (I used before 7.2) no crash
is happening, but instead I get a error message in Tcl
script: Can’t read “PostCopyInfo(PostDuplicateWhat)”:
No such element in array
Now I press either ok or skip and the message window
disappears, but the mirroring is not done.
However I just want to view and not to create the
mirrored figure, this works.
Aphrodite
What do you mean with ‘generate mesh’? Do you mean to use the ‘create’ option of the Utilities-copy window? Can you send us an example and the exact steps you followed to get to error? Have you tried the latest 7.4.9? Thanks in advance miguel -----Mensaje original----- De: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Aphrodite Kerylidis Enviado el: jueves, 01 de julio de 2004 19:04 Para: gidlist at gatxan.cimne.upc.es Asunto: [GiDlist] copy and create mesh failed Hello, I have installed the professional GID version 7.2 on my linux Redhat 8.0 computer. Everything works fine except when trying to copy and generate mesh in the postprocessing mode. My postprocessing files are written in the new format and I can open and visualize my results. I can also copy the existing mesh and view it, but I can NOT generate the copied new mesh afterwards. If I try to do it, the whole program always breaks down. I have now tried to utilize on my other computer, which has installed Linux and Windows 2000 as well, older and newer versions of GID (6.2,7.1,7.4.7), but in vain. What might be the reason for this problem? Thanks for any help. Aphrodite
Do you Yahoo!? Yahoo! Mail is new and improved - Check it out!
_Your privacy choices
=== message truncated ===
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
I have installed recently version 7.4.7b due to my problem I have got.
I briefly describe the steps I am doing which lead to the crash:
My program has calculated half of the system’s deformation figure and has
generated out of its internal data the output files deformation.msh and
deformation.res. This is possible, because the problem is symmetric and can be
mirrored. I will send both file as attachment.
I open the files in the postprocessing mode and can now visualize half of the
Then I am going to mirror the figure in order to make it whole with
utilities-copy
change to create
and press “do it”
Then with version 7.4.7 (I used before 7.2) no crash is happening, but
Now I press either ok or skip and the message window disappears, but the
However I just want to view and not to create the mirrored figure, this
works.
Aphrodite
Do You Yahoo!?
utilities-copy
change to create
and press “do it”
works.
Aphrodite
Do You Yahoo!?
