[GiDlist] Re: Can't generate surface mesh or even volume
Hi again, everyone
I am a new user of GiD. I still got the question about
how to generate volume mesh.
I have a surface geometry (see attachment). I can’t
generate surface mesh through -Meshing -Generate.
But I can generate volume entity (by creating volume
by -Geometry -Create - volume -search). When I am
trying to generate volume mesh through -Meshing
-Generate, it gave me wrong message in a pop-up
window as below.
1 wrong volumes
Num Description
1 Contour element 169 is not correct
Could anyone tell wether this is due to wrong surface
geometry, or is there any way out to fix it manually?
Thanks again!
Tom
Post your free ad now! http://personals.yahoo.ca
Type: application/zip
Desc: slab.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041014/e630be29/attachment.zip
In general, is more difficult to generate a mesh over a “surface mesh” than
over
a NURBS surface (because a NURBS is more smooth).
If it’s possible, it’s recommended to avoid to work with “surface-meshes” as
geometric entity.
In your case, for example, it’s trivial to delete all surfaces, and
reconstruct it from the boundary:
Geometry-Create-Nurbs surface-Automatic, and select with 3, 4 and 5
sides.
Then create a volume selecting all boundary surfaces, and can generate a
mesh without problems.
I attach your file modified with this procedure.
Sent: Thursday, October 14, 2004 5:27 PM
Subject: [GiDlist] Re: Can’t generate surface mesh or even volume mesh by
surface geometry
Hi again, everyone
window as below.
1 wrong volumes
Num Description
Thanks again!
Tom
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041014/2850a423/attachment.bin
