[GiDlist] questions about the results on gauss points of hex
I have some questions about the postprocessing with results on the gauss points using gid version 7.1.3. b
  1. In the attached file “prova1” I have put the gauss points coordinates in a different order respect the internal order of gid and I in the contour visualization of the scalar result I can see only the gauss points and not the whole solid . Why?
  2. In the file “prova2” I have put the gauss points coordinates in the same order of the internal one and I in the contour visualization of the scalar result I see some problem around the nodes. (in this case the scalar result is the same for all the 8 gauss points)
  3. In the file “prova3” I have put the gauss points coordinates in the same order of the internal one and the scalar result is not the same for all the 8 gauss points. In this case the contour visualization of the scalar result seems to be right.
  4. I think that gid do a local smoothing of the results from the gauss points to the nodes and then do a mean of the results coming from all the elements converging in the same node . This average value has not meaning if the elements converging in the node have different material properties . In this case is better that the finite element code do the local smoothing?
Thanks and regards,
Renato Matteazzi
Dip. di Costruzioni e Trasporti
Univ. di Padova
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment-0001.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment-0002.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment-0003.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment-0004.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/cabb945c/attachment-0005.obj
    GiD extrapolate the gauss point results to the element nodes using the element
    shape functions (this value is discontinuos between elements)
    If your gauss points are not standard (in number and “internal GiD natural” location), then
    it is undefined this extrapolation, and at this moment, GiD only show as coloured spheres at gauss points
    (in your case, the number of gauss points is the same as the internal, but in general this number can change)
    This is a bug in this particular case with all values equal. We have corrected last some problems about
    results in gauss points, but it seems that still it is left some defect.
  3. I think that gid do a local smoothing of the results from the gauss points to the nodes and then do a mean of the results coming from all the elements converging in the same node . This average value has not meaning if the elements converging in the node have different material properties . In this case is better that the finite element code do the local smoothing?
    GiD do a local extrapolation from the gauss points to the nodes, but it not make any mean (smooth) of the results.
    The calculation code can write directly the smooted nodal values instead the gauss points values.
We are thinking about add to GiD this smoothed option of the results in gauss points.
To: gidlist
Sent: Thursday, November 21, 2002 12:10 PM
Subject: [GiDlist] questions about the results on gauss points of hexahedra elements
Thanks and regards,
Renato Matteazzi
Univ. di Padova
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021121/5d5ec20c/attachment.htm
  1. for some reason GiD can not extrapolate the nodal results from
    the gauss points one with the given natural coordinates.
    we’ll check this.
  2. yes, this is a bug due to some rounding/epsilon problem in the
    extrapolation with the same gausspoints results. Now, this bug
    is corrected for the next version.
  3. ¿?
  4. GiD does an extrapolation from the gauss points results to the nodes
    with no smoothing of any type among all the extrapolated values from
    the elements which share the same node. Due to this, some discontinuities
    can be appreciated when looking at a c.fill of a gauss points result,
    this discontinuity is more obvious in elements which have different
    material properties.
thanks, hope it helps
1) In the attached file “prova1” I have put the gauss points coordinates in a different order respect the internal order of gid
2) In the file “prova2” I have put the gauss points coordinates in the same order of the internal one and I in the
3) In the file “prova3” I have put the gauss points coordinates in the same order of the internal one and the scalar result is not
4) I think that gid do a local smoothing of the results from the gauss points to the nodes and then do a mean of the results
Thanks and regards,
Renato Matteazzi
Univ. di Padova
prova3.flavia.res Type: unspecified type (application/octet-stream)
Encoding: quoted-printable
prova2.flavia.msh Type: unspecified type (application/octet-stream)
prova3.flavia.msh Type: unspecified type (application/octet-stream)
prova1.flavia.res Type: unspecified type (application/octet-stream)
prova2.flavia.res Type: unspecified type (application/octet-stream)
prova1.flavia.msh Type: unspecified type (application/octet-stream)
When i create the *.bas file, how can i chosse the sense when i write
the element’s connectivities.
Pablo
You can write each connectivity independently using the local node number as parameter of *elemsconec
for example:
*set elems(triangle)
*loop elems
*elemsnum *elemsconec(3) *elemsconec(2) *elemsconec(1)
*end elems
It exists also a parameter swap *elemsconec(swap) to change the quadratic case to non hierarchic numeration.
hierarchical numeration: first vertex nodes, after midnodes
Non hierarchical: consecutive nodes
Sent: Tuesday, November 26, 2002 2:57 AM
Subject: [GiDlist] ElemsConec in shell elements
Pablo
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021125/64bc00ee/attachment.htm
Dear GiD members,
Can we generate meshes with sets of hexahedral and
tetrahedra.
For example, there is a domain containing
Volume#1 and Volume#2.
I would like to use hexahedra for Volume1 and
tetrahedra for Volume#2.
regards,
kenji
U. of Texas at Austin
Dept. Petroleum & Geosystems Eng.
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
It is possible to obtain a mesh with tetra and hexa only in some
limited cases. In fact, to get it both volumes should have no common
surface between them and so, be independent volumes.
As you know, the hexa mesh generation must be structured.
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de kenji furui
Enviado el: martes, 26 de noviembre de 2002 5:15
Asunto: [GiDlist] MeshGeneration
Dear GiD members,
tetrahedra.
regards,
kenji
Do you Yahoo!?
If the volumes are independents it is possible to mesh one with hexahedra
and another with tetrahedra.
If the volumes share some surface, then it is not possible: not exists a
conformal mesh.
Sent: Tuesday, November 26, 2002 5:15 AM
Subject: [GiDlist] MeshGeneration
Dear GiD members,
tetrahedra.
regards,
kenji
Do you Yahoo!?
http://mailplus.yahoo.com
kenji
conformal mesh.
Dear GiD members,
tetrahedra.
regards,
kenji
Do you Yahoo!?
now.
Do you Yahoo!?
Hello:
An additional comment regarding Kenji’s question. This topic has already
been discussed outside the GidList context. Mixing tetra and hexa meshes
requires pyramids to make the transition (pyramids are supported by many FE
codes). This solution would be useful for problems such as acoustics, for
instance, where tets perform poorly (but geometries are too complex to mesh
with hex only).
Philippe
At 11/26/2002 08:00 AM, you wrote:
kenji
conformal mesh.
Dear GiD members,
tetrahedra.
regards,
kenji
Do you Yahoo!?
now.
Do you Yahoo!?
