[GiDlist] problems with win2000
I am using GiD 6.1.2 under win2000 and some troubles occur.
At each calculation lunch trough the “calculate” menu 2 virtual disks
appears…
What can I do to overcome this problem ?
Is a recent version available ?
Another problem is that it is impossible to open your FTP window for
downloading beta versions.
Thank you for help.
Zoubir Khatir,
Laboratoire des Technologies Nouvelles (LTN)
INRETS, 2. Av. Malleret-Joinville, 94114 Arcueil Cedex
Tel: (33).01.47.40.73.34 Fax:(33).01.45.47.56.06 mail: khatir at inrets.fr
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020107/f2b82572/attachment.htm
In some Windows versions the system does not allow GiD to erase these auxiliary virtual units.
It can erase them manually from a DOS console with: subst “unit” /D
for example, if the unit is named F:
subst F: /D
To correct this and others problems, In the last beta versions, the file *.bat is directly interpreted from GiD (without use the command.com of the operating system).
The last beta version for Windows is:
ftp://gid.cimne.upc.es/pub/gid_adds/Windows/GiD6.2.0c-win.exe
It is the first notice about the impossibility to acces to the beta versions
What explorer version uses?
Sent: Monday, January 07, 2002 5:57 PM
Subject: [GiDlist] problems with win2000
At each calculation lunch trough the “calculate” menu 2 virtual disks appears…
Another problem is that it is impossible to open your FTP window for downloading beta versions.
Thank you for help.
Zoubir Khatir,
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020107/cababbf1/attachment.htm
I am using Internet Explorer 5.5
When I try to access to the ftp site, I have system troubles…
subst F: /D
operating system).
_ftp://gid.cimne.upc.es/pub/gid_adds/Windows/GiD6.2.0c-win.exeftp://gid.cimne.upc.es/pub/gid_adds/Windows/GiD6.2.0c-win.exe_
To: mailto:gidlist at gatxan.cimne.upc.esgidlist at gatxan.cimne.upc.es
appears…
Thank you for help.
Zoubir Khatir,
web: www.inrets.fr
Zoubir Khatir,
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020108/7181fe5a/attachment.htm
Try to update the Explorer to last version 6
(it is recommended for greater security in front of viruses)
If it is not possible download GiD (12.864 Kb), we can send it, split in several pieces by e-mail.
Sent: Tuesday, January 08, 2002 10:13 AM
Subject: Re: [GiDlist] problems with win2000
subst F: /D
Thank you for help.
Zoubir Khatir,
web: www.inrets.fr
Zoubir Khatir,
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020108/b73eb8ec/attachment.htm
Hello all!
I have tried to make those post-processing files by hand for programming
purpose but it doesn’t seem to work properly. Can someone point out my errors?
Thanks in advance.
Olivier Bounhoure
GiD Post Results File 1.0
GaussPoints “Gauss” ElemType Quadrilateral
Number Of Gauss Points: 4
Natural Coordinates: Internal
End GaussPoints
Result “Gauss_element” “Load_Analysis” 1 Scalar OnGaussPoints “Gauss”
Values
1 .39269
.39229
.39166
.39232
End Values
Maillage fait à la main
Mesh “Maillage” Dimension 3 Elemtype Quadrilateral Nnode 4
Coordinates
1 0 0 0
2 1 0 0
3 1 1 0.2
4 0 1 0.2
End Coordinates
Elements
1 1 2 3 4
End Elements
Hallo Mr. Olivier Bounhoure,
the files are o.k., as you can see in the attached image.
Which version of GiD are you using?
The new postprocess format works for GiD version 6.1.4b or later,
which you can find at:
Olivier Bounhoure wrote:
Hello all!
Thanks in advance.
Olivier Bounhoure
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020107/e8a372fe/attachment.gif
That’s the point!
I wanted to try the GiD 6.1.4b for linux version but this doesn’t seem to
work corectly.
The error message is:
problems getting information about gauss points ‘Gauss’, in line 6 of file
‘/home/olivier/nouveau.flavia.res’.
Unknown key ‘Values’,
in line 7 of file ‘/home/olivier/nouveau.flavia.res’.
Can two installations of GiD bring conflicts? I have the 6.1.3 in
/usr/local/lib/gid and the 6.1.4b in /home/olivier/GiD/gid6.1.4b.
Thanks a lot
Olivier Bounhoure
Le Lundi 7 Janvier 2002 18:43, vous avez écrit :
_ftp://gid.cimne.upc.es/pub/gid_adds/_
Updatre to the Linux version 6.1.5b
ftp://gid.cimne.upc.es/pub/gid_adds/Linux/gid6.1.5b.tar.gz
From: “Olivier Bounhoure” olivier.bounhoure at club-internet.fr
Sent: Monday, January 07, 2002 7:14 PM
Subject: Re: [GiDlist] New postprocessing format
That’s the point!
work corectly.
Thanks a lot
Olivier Bounhoure
I tried this version before 6.1.4b but it fails on execution with the
following message:
gid.exe: ../iconv/skeleton.c:302: gconv: Assertion `outbufstart == ((void
*)0)’ failed.
Abort
Is there anything to do?
I have noticed the archive of 6.1.5b is much smaller than the 6.1.4b one. It
is a bit surprizing… Is it normal?
Olivier
Le Lundi 7 Janvier 2002 21:24, vous avez écrit :
_ftp://gid.cimne.upc.es/pub/gid_adds/Linux/gid6.1.5b.tar.gz_
The change of sizes is normal:
The package 6.1.5b is small because it not include some formats (tex,ps,..)
of the reference manual and the sample problem types.
I suppose that the execution error is corrected, but not we have still
compiled the last 6.2.0c beta version for Linux.
Sent: Tuesday, January 08, 2002 2:55 PM
following message:
*)0)’ failed.
Abort
It
Olivier
