[GiDlist] Problems with the tool "Take a snapshot"
Good afternoon,
I am trying to “Take a snapshot” of a geometry in preprocess mode and I
can not do it. In postprocess mode I do not have any problem to take
pictures.
The Warning I obtained for png pictures is: Unknown extension ‘.png’
I also tried with .jpg and .gif extensions with the same result.
Can yo help me?
Thank you vey much,
Joaquín Irazábal González
Ingeniero Industrial / Mechanical Engineer
CIMNE
Paseo Gral Martínez Campos, 41, 9º Izq.
Madrid 28010
Tel. +34 913 191 359
jirazabal at cimne.upc.edu
www.cimne.com
AVISO IMPORTANTE
Los datos de carácter personal facilitados están registrados en un fichero con la finalidad de facilitar la gestión de las comunicaciones de CIMNE. Puede ejercitar los derechos de acceso, rectificación y cancelación respondiendo al presente correo electrónico.
AVIS IMPORTANT
Les dades de caràcter personal facilitades seran registrades en un fitxer amb la finalitat de facilitar les gestions de les comunicacions de CIMNE. En qualsevol cas podrà exercir els seus drets d’accés, rectificació i cancel·lació responent a aquest correu electrònic.
IMPORTANT NOTICE
All personal data contained on this mail will be processed confindentially and registered in a file property of CIMNE., in order to manage corporate communications. You may exercise the rigths of access, rectification, erasure and object by replying this email.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120530/a0cb3a12/attachment.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120530/a0cb3a12/attachment.png
How are you taking the snapshot?
I have tried with GiD 11.0 Windows x32,
from the menu Files-Print to file-PNG
and
from the camera icon or the upper icons bar, and selecting Files of type png in the window that is opened
and it worked in both cases
Which platform are you using? (Linux, Windows, x32 or x64)
Sent: Wednesday, May 30, 2012 4:28 PM
Subject: [GiDlist] Problems with the tool “Take a snapshot”
Good afternoon,
I am trying to “Take a snapshot” of a geometry in preprocess mode and I can not do it. In postprocess mode I do not have any problem to take pictures.
Can yo help me?
Thank you vey much,
CIMNE
Madrid 28010
www.cimne.com
AVISO IMPORTANTE
AVIS IMPORTANT
IMPORTANT NOTICE
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120531/b5723781/attachment.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120531/b5723781/attachment.png
Hi all,
with all GiD versions I’ve tried (9.x, 10.x, 11.x) the “Create Result”
option in the “Window” menu of postprocessing is not working properly.
Namely I have noted two issues:
  1. When I want to pick an operand result from a long list I have to click
    “..More…” on the dropdown menu. Choosing the result from the “View
    Results and Deformation” window which popups thereafter has the only effect
    of changing the DISPLAYED results and does not change the result chosen as
    “Create Result” operand, instead.
  2. Whenever I try to create a new result from results defined at Gauss
    points I have the following error:
found an error
while executing
“GiD_Result create {*}$res_dst”
(procedure “PCRApply” line 409)
invoked from within
“PCRApply”
invoked from within
".gid.wPostCrearResultado.but.apply invoke "
invoked from within
".gid.wPostCrearResultado.but.apply instate !disabled {
.gid.wPostCrearResultado.but.apply invoke } "
invoked from within
“.gid.wPostCrearResultado.but.apply instate pressed {
.gid.wPostCrearResultado.but.apply state !pressed;
.gid.wPostCrearResultado.but.apply instate !di…”
(command bound to event)
Is this ever going to be solved?
NL
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120601/9128da10/attachment.htm
